Dave burke
- Near Lake Placid
- X
Thanks to all that I’ve learned about stereos by following all the experts on this site, I’m thinking about a series upgrade to my stereo.
Before I get into what I’m thinking of changing, here’s what’s in the boat currently (all factory installed):
- Polk DB651’s in the bow and rear cabin
- Polk db521’s on the swim deck
- WS Stealth 10 soundbar
- Polk MM1040UM sub
- Polk 5 channel amp, PAD5000.5, 70w x 4, 200w x 1 RMS @ 4 ohms
- bow and rear cabin speakers are wired in series; same thing for the soundbar and swim deck speakers
Here’s what I’m thinking of doing:
1. Add a pair of front cabin speakers, ideally db651’s. I’d like to mount them high like several others have done. Not sure I can do that given the offset shape of the black liner (pics included). Maybe I can mount a smaller speaker like a 5.25 in. Which begs the question, am I better to do this or mount the 651’s down low
2. Change the swim deck speakers to db651’s. I think they’ll fit
3. Change the sub to a JL M10IB5. Should I consider the JL MX sub or maybe a WS IB sub?
4. Wire the bow and front cabin speakers in parallel. Do the same with the rear cabin and swim deck speakers
5. Use the polk amp to power the sub and bridge the other 4 channels to power the soundbar. The recommended power is 150 w per channel and the bridged amp is 200 w per channel. Is this too much power?
6. Last but not least, add a 4 channel amp to power the other speakers. I was thinking about 200w per channel at 2 ohms which means that each speaker should get about 100w. The Polks are rated at 60w RMS and 180w maximum. Does this seem like the right power?
7. For the amp I’d like to add, the choices I’m considering are the Polk 4000.4 (200w x 4 @ 2 ohms), the WS Syn dx4 (same power) and the Fusion MS-SG41400 (220w per channel). But the Polk is 1/3 the price of the WS and half the price of the Fusion so I’m leaning it’s way. Should I consider other options or other amp combinations?
Appreciate any advice. Many Thanks.
- Polk MM1040UM sub
