I agree about the grill on the swim deck. I plan to buy this bow mount this spring. http://www.grillamount.com/index.htmlThis is what I did https://jetboaters.net/threads/mounting-magma-grill-on-the-bow.2842
I had a grill that I used on top of the table. It seemed that every time I grilled people would start getting on and off of the boat. The hot grill was dangerous at the swim deck. I vastly prefer it mounted at the bow. The swim deck is open for family enjoyment while I grill in the bow.
Did you get yourself set up for grilling on your new boat?purchasing ar240 2015..... Want to get mount and grill to fit into the table holder slot. Is there a full set up we can purchase?
You have a nice setup, and you did a great job with the write-up to share it. I'm leaning toward using the table mount on the swim platform to mount the grill on. I don't want to drill.Did you see my write-up?
https://jetboaters.net/threads/ar192-magma-kettle-2-grill-install.6262/#post-107407
@Speedling Okay I finally got around to installing a rod holding in the boat to use for the grill. Making that first big hole in the boat left me a little queasy!I have a second rod holder that I will hold onto until I try this location and see if I want to add another elsewhere on the boat.
