Looking to upgrade towner speakers, Samson, Wetsounds, or JL Audio
cybuch
Gilbert, az
Hey there,
I currently have a 3 inch tower and have gen 1 Samson speaker cans, loaded with some MB Quart speakers. I am looking to update the tower cans/speakers. what I don't like about my current Samson cans is, the there is a release pin you pull to install them and then you lock them in place with a knob, the knob comes loose often. I do like that I can remove them quickly.
Looking at the JL Audio, they look really nice but the swivel mount will not fit my 3 inch tower, I can go fixed, but I like to switch the speakers from front to back depending on our sport, wake surfing or flyboarding. Maybe face 2 to the rear and 4 to the front?
Looking at the Wetsounds, they need a tool to swivel them, not a huge deal, anyone have them and can share if it is a PITA?
Looking at the Samson, the locking is a knob again and no safety locking pin if the knob works its way loose. Anyone have these they can share info about?
Any input would be great!
The newer Sampson speakers are the same speaker as Exile Audio. I had Exile before I had Wet sounds. It was a great speaker. The knob that you are referring to on them also had a spot to insert an Allen wrench. You would want to hand tighten and then snug it up with an Allen key to make sure they are tight. The Wet sounds system is slightly more complicated, but I feel it also slightly more solid. I'd say the Exile were definitely easier to remove/rotate, and I never had an issue with the clamps/mounts. The Wetsounds is probably a little more solid. Just as easy to rotate, but a little harder to remove/install. You will need a tool to remove/rotate/install both.
Thank you! this helps a great deal!
I have REV8s with swivel clamp and they are easy to put on and take off, I garage my boat so I put them on and take them off pretty often and they've been solid.
I have the WS Icon8 on the swivel quick release mount. One allen screw to swivel or remove. I bought the allen wrench needed as an individual for the boat. Easy to swivel or remove.
Wetsounds REV10s on swivels here. Super easy with an Alan Wrench and built like a tank.
What about the new Kickers? I know they swivel completely.
Rev10's swivel is really nice, of course they are the only ones I have experience with. I got a t-handled allen wrench that I keep on board. You slide the fork in to lock the speakers to the mount ( so you don't have to hold them), then tighten the allen wrench, super simple and quick.
