That makes me feel claustrophobic just looking at those photos. I've done the front cleat, and changed the swimdeck remote. I wish I would have had someone pull me out by my feet. It would have saved a few fiberglass slivers!!
@Sean Buckhannon just realized your's was an '06 you might be able to get to if from your access/storage area at your step over, maybe there is a false wall you may have to remove,
I assume you finished already but if not you need to find a slim 14 or 15 year old. I have tried but don't fit. I did mine yesterday with the help of my daughter.
1 remove bilge hose where it attaches to the outside so you can remove the plywood board in the back. the plywood part is attached by 3 screws. once unscrewed remove the board. The cleat and screw or lack thereof becomes visible. I found one of the nuts in the back accessible through the clean-out hatch. Thereafter, applied blue thread-locker to the screws, washer and nuts. I torqued it to 17 ft/lbs although I'm not sure that's the correct torque. I also had applied silicon sealant to the underside of the cleat on the outside.
Reattach plywood and refasten bilge hose.
It's not bad with a small person. I have tried it on and off without success. 6.5' 250 lbs. I also tried from the cleanout tray but not possible on the 2009 210 I understand might work on the 240.
Good luck
