Low compression and won't go over 2000 rpm
LS
We replaced one engine Dec2023, it has never run really exact right since. We had it back at the shop several times last year and they kept finding other things wrong but never completely fixed it. Over the winter we replaced all the fuel lines and the exhaust hose on that engine. It still won't go over 2000 rpm. We took it back to the shop and they did a compression did and said that the new engine is blown and out of warranty. Is there anything else that could be causing it to have low compression before we completely replace the motor or so it for scrap.
what do the spark plugs look like those are the report card of a 2 stroke pay attention to each plug , was the engine rebuilt previously?
New engine was put in last year, supposedly new not rebuilt. I do not think the spark plugs have ever been changed though, as far as I know they did not do that when they put the new motor in and we have not changed them but we have only owned it for 2 years.
Not what I meant the plug will tell you if there is an issue with the engine and the tips tell all, but You also need the exact reading of each cylinder on a compression test
New engine but put old plugs in it? That doesn't make any sense. No one would transfer old plugs to a new engine
Well we're not sure they really put a whole new engine in and didn't just re sleeve an old engine. That and the fact that it was in the multiple times last year with us saying it's not right and they never did a compression test till now when it's out of warranty and it only had a year warranty. I have no faith in them and what they actually did
Well I'm sure it was a rebuilt engine not a new one as no one is building new 65u/66h 1200 NPV engines. There is also nothing wrong with a rebuilt and re sleeved cylinder that is how they replace the worn parts on a rebuilt engine. Unfortunately once an engine has low compression the damage is done there won't be a easy fix. Properly rebuilt and adjusted carburetors and a maintained oil injection system (if still installed) is critical to a two stroke engine. Two Stroke engines are high performance machines if they are not running right and properly, damaged is probably being done. Maintaining and owning a two stroke engine is part knowledge, part art, and part love. If your shop allows your boat to leave and it's not running right when you get it it's time to find a new shop or better yet learn to maintain it yourself.
