Red323red
- Limited S
I took my Yamaha 2011 242 limited s and the port engine will not go past 5 RPM did a compression check and found that cylinder two and three reads 60, 70psi. The boat has over 500 hours. I was thinking of using ENGINE RESTORE to help build up the compression. Does this sound like a good idea?
