- Royal, AR
- SX
We have an unusual dual battery setup which includes a BlueSeas LVD on our boat. We also have a refrigerator which consumes 1Ah per hour.
We left the refrigerator running with one battery switched on for the tow home from Bimini. That battery ran down to 12.1 volts which is roughly 50% so it was disconnected by the LVD. I switched to the second battery when I flushed the engines and washed the boat. Then we tucked her away in the garage and plugged in the onboard charger.
Early Saturday we headed out to the lake to take family out for lunch then friends for dinner and fireworks. Fourteen people were planning to enjoy our boat that day between the two groups. The boat had been plugged in for days so we expected the batteries to be charged.
After launching @Rana called to tell me that the accessory switches would not light up. The engines are not connected to the LVD so they continue to start and operate even after the LVD has cut power to the house circuit(s).
After getting to the boat I confirmed that the LVD had tripped and both batteries were discharged to 50%. We picked up our family members and headed out to an island. During that run one of the batteries charged from 12.1 volts to 12.3. We used some of that charge to inflate a paddle board and cool the refrigerator down while hanging out with the morning group. I also changed the disconnect voltage from 12.1 (50%) to 11.7 (30%). I discovered that the power wire for the onboard charger had come loose from it's crimped on connector. I soldered it into place so that will not happen again.
We boated back to the marina and swapped guests then headed to a cove near where the evenings fireworks would be. We enjoyed music, a cold refrigerator, chart plotting and as the evening approached we turned on the LED Cupholders. We only used one battery keeping the second in reserve.
We enjoyed a great day on the water. The LVD saved us from having two fully discharged batteries and likely having to buy replacments. Starting the day with a 50% charge was not optimal but was so much better than if the engines had failed to crank! For our guests it was just a normal day on the water.
