AuburnVFR
- Auburn, AL
- SX
I'm currently looking around for a used SX190 and have a question if I can even consider an AR, since it seems there are more of them on the market. The main issue against considering the AR is that I need to be able to go under a low abandoned railroad trestle on the lake. Depending on water levels, I normally have to lean over while driving the in-laws pontoon, so I'm fairly certain a raised tower will not go under.
Is it practical to lower/raise the tower on the AR while on the water? Would the older or newer style tower be better in this regard? Is it possible to remove either tower and replace it with a regular Bimini without it looking like total crap?
FYI, I don't really have an interest in skiing or towing sports (other than an occasional tube) and the second captains chair seems more appealing to me than the bench layout, but I'm certainly not opposed to a good deal on an AR if I can navigate under the trestle with some level of practicality.
Thanks
Thanks
