DavidLS2000
- LS
Hello fellow Jet boat owners.
I have a 1999 LS 2000 with 2 135 hp engines. The boat was a real mess and I have been trying to bring it back. After removing 9 year old gasoline, I removed the oil pump coupler and put in premix into it. I got it running and have had it out on Lake Erie 5 times. It is a fun boat. A number of things still need attention.
I replaced the oil lines with ether polyurethane hose and ss wire ties. Since the boat had sat for 9 years I am leery of the oil pump output. I have looked all over for answers and have not exactly found what I want. I am looking for the oil output of one carb/cylinder line at 2 minutes at 2000rpm? 3000rpm?
4000rpm? 5000rpm? not touching the oil pump pulley other than having the throttle opening it.
Regards,
David
Regards,
David
