swatski
Jetboaters Fleet Admiral 1*
- North Caldwell, NJ
The way the L13 works is pretty simple. Basically, it increases the efficiency of the pump by increasing pressure and thrust.
I have previously installed and tested a Lucky 13 in a single engine 190, but it is a long thread. https://jetboaters.net/threads/anyo...ce-adjustable-pump-cone-in-a-boat.7967/page-2
Needless to say, I liked it so much I decided to get those for the new 240.
THE RESULTS
I love those cones. Have not done any tweaking or tuning at this point (here, with the new boat), just installed the cones using all 3 spacers provided and ran around a bit to see how it feels. Hard to describe the effects, but the boat handles "tighter" and accelerates better, which is due to improved pump loading. Top speed and RPM are the same, but speed can be improved by tuning the cone and the impeller/venturi. I have NOT done ANY tuning here, yet the boat runs noticeably better with the L13 (strait out of the box) than w/OEM cones.
L13s were sourced from greenhulk store https://www.4-tecperformance.com/index.php?main_page=index&cPath=207 Those are very high quality parts. The base is tapered 3deg, but it is hard to see in the pics. It has 3-bolt base (distinct from SVHO that has 4).
The hardest part (!) was getting the OEM grease (called "EPNOC grease AP #0" or "EP") for the pump bearing. I wanted to stay with the OEM grease. After a long search found the US equivalent ("Mobilux™ EP 0") here:
https://redidriver.com/my-redi-driver-store/8-oz-ep-0-grease-for-redi-driver-free-shipping-in-usa/
INSTALL
First step -- pulling the pump. This has been documented elsewhere, but here are few quick easy steps that I follow, same/similar on both sides:
Note that my boat has the additional (port side) steering rod (from @Cobra Jet Steering LLC). A long wrench extender comes in handy to reach 4 main (also long) bolts that hold the venturi segment.
Don't loose those pesky dowels (there are 2):
Note that at this point the stator (pump bearing housing) segment of the pump can be pulled out, along with the impeller and the shaft. However, there is no need to do so for this particular mod.
The OEM cone is attached w/ 3 allen bolts/washers that are reused in L13. There are notches in the OEM cone that fit a flat screwdriver for prying the cone off. The aluminum flange is soft and there is an O-ring on the inside that can be damaged, so proceed carefully, these are critical parts for pump maintenance:
Here, there is no evidence of water intrusion, and everything looks fine inside this housing.
Here are the two cones side-by-side. Quite a difference in size! Note, the base of the L13 has smaller cavity.
IMPORTANT - the OEM O-ring needs to be moved from the OEM cone to the base of the L13 (red arrows):
Here comes OEM grease, it is semi-liquid. I used approx. 2oz. of new grease per cone. Ambient temps are low, but even at room temp this stuff is easy to handle and not too runny.
The base of the L13 is tapered and it is important to install it with the small engraved letter "T" towards the top (which will center the cone inside the venturi):
(The "top" bolt is OFF center to the left, in both pumps)
The base needs to be separated from the "cone" to gain access to bolt holes. I use a bit of LockTite on the allen bolts since the base stays in the pump. There is a small O-ring, and the spacers can be loaded and exchanged WITHOUT removing the base. This is very important - once the base is on, spacer adjustments can be made without exposing the critical pump bearing.
Running on single engines, each gets the boat to 30+ mph (up from approx. 25mph with OEM cones).
There is still a lot of cavitation running with one engines. The L13 can not prevent this although it does help.
Top speed and RPM are unchanged in my boat with this setup, running at about 50-52mph top. This can be further tuned, either for higher speed or better hole shot/acceleration.
Done. There will be more tuning and testing, TBA.
THE RESULTS
INSTALL
