Lucky13 2023 sx190
ryanotown22
Any benefit of the lucky13 on newer boats? I have a 2023 and pull tubers a lot and notice my corners really really bog down the speed trying anything to help..
I have one installed on my 2019 SX190 and I still bleed off alot of speed when turning, especially when pulling tubes and trying to whip them outside the wake. Lucky13 cone really helps with holeshot though, no cavitation on take off even if i go full throttle.
Hey Ryan,
I have one I may be selling soon if you want to save some money over new.
Let me know if you're interested and I can get some pictures for you.
Add my super steering it makes the turns a lot faster gets rid of the bow wander and a lot more for all speeds not just docking.
I actually already purchased the cone but was just debating if I should put it on or not
I just finished the cobra jet steering but was not sure on what setting to put it on I put it on 5/6 the little middle actuator has a slight tweak in it you can see in the photo where it raises up the left fin. I am guessing I need to take that apart and slightly bend the actuator so the fins are levelIMG_1258.jpeg
Ryan,
I think you might have gotten an incorrectly bent cross brace, mine was bent wrong and CobraJet replaced it. You might want to reach out.
The bend in the actuator was me being bad at following directions Jeff got me straightened out and it’s fixed.
