Lx2000 starboard engine issue
RR62800
LX
Boat was running great all summer. Yesterday running wide open 7000rpm the Starboard engine shutoff. Any thoughts. Wouldn’t start after that
glad to have you on board, update your profile with your location so we know where your at,
how long have you owned the boat?
are you running pre-mix or oil lines? if oil lines are they original with zip ties ?
does the starter turn the engine and it just doesn't fire ?
Have you checked to see if you have a spark when trying to start?
Have you checked to see if your getting fuel to the carb ?
If the engines turn over, and if all three cylinders have good compression, it could be your stator. My neighbor has the LS2000 and had same issue. He bought a stator off eBay for $80 and it fixed his issue.
