sclx210
- LX
I have 2003 LX210. I ran into issue with port engine not cranking. When I turned on the key, I hear a click sound from the starter and then nothing. Could this be issue with the starter motor? The port engine was running fine back in Nov to winterize it and have not use it since. Last weekend July 4th was my first time started the port engine and faced this problem. It couldn't be engine seize before it was running on the lift back in Nov, right or could it? The starboard engine started fine. I appreciate for any guide to trace down the problem. Thanks
