platinum00
- AR195
Sorry can't help you there, I want to know the same thing honestly. Would love to put an amp on the cabin speakers myself. I already have an amp on my towersUsing amp for cabin.
Low level rca out of the ma200 deck to amp. Amp to stock speaker wiring.
I can run new wiring but only doing about 60rms so the stock wiring is fine at 4ohm.
Looking for connector for the stock speaker harness so I don't need to tap or cut it incase I want to go back to stock.
Looks like a fairly standard Molex style connector? Try an electronics shop.Adding a amp to a MA200 deck. Was wondering if anyone makes a female connector for the speaker plug before I cut the end off.
Agreed.Looks like a fairly standard Molex style connector? Try an electronics shop.
PS - if the stock wiring is 14awg you can run about 200w through it without issue.
Good info for others, thanks for finding and posting!It works.
You want a Scosche VM01BCB adapter. It was $5 on amazon.
Amazon.com: Scosche VW01BCB Compatible with Select 1986-04 Volkswagen/Audi Euro vehicles Power/Speaker Connector / Wire Harness for Aftermarket Stereo Installation with Color Coded Wires and Pre-installed Wire Connectors : Electronics
Also if you happen to have a MA200 head unit that does not have the remote wire for your amp. Some, like mine, only have power and ground, get the Scosche ST01RB kit. It has the plug that will add the remote wire. That one was $4 on amazon.
Amazon.com: Scosche ST01RB Compatible with 2008-14 Smart Car Power/Speaker Connector/Wire Harness for Re-Installing The Factory Stereo with Color Coded Wires : Everything Else
So for under 10, no cutting or splicing wires.
