Weeb
- Denver NC 28037
I ordered @Mainah's push start mod and shrill to chill mod as well as fender covers. I couldn't be more pleased with the parts or their results. All of the wires going into the push start controller are cover with some type of hard epoxy so the wires can't rust or pull out. The alarm chill mod is also covered with this. Installation of the push start was easy, I went the @swatski route with the buttons by the blower switch there isn't much room for error with the holes so there was a lot of triple checking measurements. The wiring is all plug and play. The chill mod is also a real easy install. The wiring diagram didn't match up with what I had (because 15-16 are different than 2017). I talked to him on the phone and sent him a couple of pictures of my wiring and he had it figured out in no time. It's so nice to start the engines and not have that connext alarm screaming. The fender covers are great and will keep them from rubbing the wax off and scuffing up the boat. Thanks Chris you were a pleasure to deal with.
