Maintenance screen reset
afdouble
Upstate, South Carolina
242 Limited S E-Series
SO, I have an E-Series boat that has a Connext Screen that counts down when maintenance is due. It basically looks like the gas gauge, but ranges between 0-100 hours.
I completed my 50 hour maintenance, and would like to reset it back to 100 hours. Does anyone know how to do that?? It currently reads 33 hours remaining.
Not sure. I just hit 100 hours a few weeks ago and the alarm went off. Once it did, it was an easy reset.
Have you tried holding down the "Sys Control" button below the screen? I don't have the boat directly in front of me, but I'm thinking off the top of my head, the menu to reset the counter was in there.
I think that is the problem, it is easy to reset once it hits 100 hours..and perhaps the only way to reset it absent factory help. The manual states the sys control screen will have a screen to clear it at 100 hours, but it won't pop up until then. I didn't see anyway to reset it on the sysy control screen, and i played and toyed with every button possible...
Happened to me this weekend on the FSH210 and I just had the 100 hour service done. I’ll post when I can figure it out I tried but have not been able to yet. And only popped up on the starboard motor.
Just got the 100 hr maintenance warning for the port engine. Any new insights on where and how to reset?
warning won’t let you and the systems menu doesn’t appear to let you do it either......
Boom found it.... for anyone with the eseries you find it under Settings and then select “Wellness” them reset. Makes perfect sense, right?!?!?
Appears that the reset is only good for the trip. Every time we fire the boat back up the alarm goes off and we have to reset it again The dealer mentioned that there is a Connext Software update to fix a defect with engine hours being different between the two engines, there's an off chance this is related.
In either case, has anyone else experienced having the reset their maintenance hours (100 hrs in this instance) under the Wellness tab to only have it report the full hours and trigger the alarm on subsequent trips out?
Seems backwards if your boat is counting down. They normally count up from the last reset back to zero.
Have the same issue. ALARM is easy to deactivate but it only good for a trip.
I’m having same thing on my 212X. Alarm started at 100 hrs. If I hold SYS CTRL then go to Settings, I don’t have a “wellness” button if any kind. There has to be a way to reset this alarm. I’ll email my dealer and ask.
Were you able to resolve the issue?
Nope. Not yet anyway. Dealer got back to me and said they could walk me through it. But by that time I’d already put the boat in storage for the season. I’ll have to tackle it his in the spring. When I do, I’ll make a video and drop it on YouTube.
Thank you. Look forward to seeing your video once you done.
Ok, so I think I found it. went to the screen where I see the number of hours left. Pressed the wrench on the screen, then I held the joystick down for a few seconds. It asked me if I wanted to reset. Used the joystick again to select yes.
Hey Reno!
You ever get this sorted out? I changed the oil and filters yesterday (yup, been sitting all winter) and couldn't figure out how to reset the hours on the maintenance screen.
