Geoff Cooper
- Thailand
This was the Trailer before i examined it as you can see it looks ok
Only a few weeks before joining this website i popped into the Yamaha main agent to collect some documents and while i was there i noticed 2 x SX 230s parked on the front which looked a little strange so i decided to take a closer look and to my amazement both had the front of the trailers snapped and were completely detached on one side, After speaking to the parts manager he informed me that this had happened while being towed and was not uncommon, That got me thinking so when i got back i took a very close inspection of my trailer only to find cracks and corrosion damage in the very same places as the ones in the agents car park.
Ok time to do something about this as it appears to be a fault on older trailers, The very next day after considering my options and very close examination i set about carrying out major structural repairs by cutting off the metal from the first support nearest to the winch post all the way to the first cross member under the bow, Once removed i could see the amount of corrosion inside the metal channel of the trailer these go rotten from the inside out and consequently it's often not noticed until it's to late.
I went to a local steel stockist and found some steel section which perfectly fitted inside my original trailer frame with a little persuasion so after cleaning all the relevant parts and linishing the surfaces to be welded i set about rebuilding it, I didn't like the bend that the original trailer had in the front arms as this was where the corrosion had occurred so i changed the design a little and after a full days work welding and fabricating some strengthening supports the job was finished.
I would suggest that a closer inspection of these trailers is taken as these boats that were parked in Yamaha were 08 models and mine is an 06, You can just imagine the extent of the damage if one of these came adrift while being towed, It's not easy to spot on Black trailers and not something you go around looking for, I have taken some photos and i will try to put them on here but I'm still learning to navigate my way around here, Please go and check it only takes a minute and can save an awful lot of trouble, This was a non galvanized MFI Trailer which came supplied with the Boat and it wasn't until i went poking around with a screwdriver that the cracks appeared, The fenders have been removed because I'm making new ones from Checker plate so take care,Good Luck
#Pictures added by Bruce
