Foobar
- Charleston, SC
- FSH Sport
Ok, so I started cutting holes today for an in hull transducer. (epoxy to the inner hull. no holes.) In the engine compartment many Yamahas have a cutout for the bilge pump. So, there is a clear spot under the starboard engine. I cut a hole into what I am going to call the inner hull. (I know, technically not.) The piece would not come out. I cut a small piece from the square so I could pry it out.
I found this very dense gray material between the two hulls, which stopped short of where they put the bilge pump sits. My thinking is that the transducer should be able to shoot through this material as it seems very dense. So, I patched the cuts back up with Marine Tex. Tomorrow I will sand and finish it. (8 hours wasted between cuts and repairing)
Does anyone have experience with using a transducer on top of this material? If I don't have to remove a square of it, I would prefer that. Removing a 4x4 square of it would involve a lot of knuckle busting.
