QBoater519
- Other
- Other
Hi eveyone,
I have a 95 Euroline jet boat with a Merc 120XR jet engine. I have clean the carbs, pump and filter. Added new fuel after removing all old fuel was sitting for 8 years.
Checked compression in all 4 cylinder around 120psi. New spark plug. Added a new thermostat since it was only $20 bucks. Chained the engine oils and bottom propeller oil and also the oil reservoir too.
Boat fires right up and run normal for 2-4 minutes. I connected a hose since im running it in my driveway for water cooling.
After it warms up 2-4 minutes it starts to rev up by itself without me touching the throttle and starts to overheat since a solid beep alarm comes on.
I then turn it off and let it cool for 30 minutes.
But it keeps doing the same thing over again.
Is there a water pump that might be bad?
Maybe something stuck in the waterline or water vent casuing it to over heat?
Any advise on troubleshooting this overheating.
Thank you for any help.
