blacksapphirez
- Charleston, SC
- SX195
so I got brave and tore up my engine... na it wasn't that bad. just removal of the air filter and throttle body. I saw the AR190 write up and thought i have to remove the entire intake manifold but na our's is bit easier. 13mm and a hex bit
that flame arrestor is in there very tight...had to fight a good bit to get it out without damaging the aluminum intake manifold... but gained 2mph and 200~250rpm. Very quick BUT...cavitates out of the hole. may need higher pitched impellers ...
