Before we got back into boating we rode sidexsides and the forum I frequented then had this thread...Post up your best and cheapest mods (preferably with photos).
(LOL) Now you are talking my language. Cheap maybe, but I like to call it being frugal.....head storage in previous topic.....quick release flag mount in previous post.
Here is how I solved the problem with the head door not staying open, it drove my wife crazy. I used a 1 inch circular magnetic door latch rated at 40 pounds of holding strength which seems to be the right strength. I also install the door bin on the inside of the head door to hide the magnet mounting screw. On the head wall I used a piece of PVC house trim to create a wedge at 8 degrees so the latch washer will be at the same angle as the door magnet. The screw through the latch washer and PVC trim is 3/4 inch and just barely goes through the fiberglass and does not come through the carpet on the inside.
I did this mod 2 years ago and we still enjoy it. Now the door does not close on the wife when the boat rocks. I have since painted the magnet and washer white which makes them now almost unnoticable.
The magnet latch cost $8.00 and I had the PVC trim left over from a different project.
Bottom left mount screw changed to bolt to hold the magnet.
Looking down from above the head door with it open and held by the magnetic latch.
On my boat it is probably the pipe insulation I used to seal off the engine compartment opening with, under $20 at Home Depot. Not sure how much it helps but it has to be better than what I had stock and it's in use whenever the boat is running. I forgot about the cam locks I added to the head compartment and helm doors, $6 each at McMaster Carr.
On the trailer, it's the boat buckles but cheap is a relative term, these things were around $80 I think and the stainless models are more. Scratch that, it's the magnetic D key, $12 on ebay. I'll take a post pics tomorrow.
I didn't get pics of the D keys or Cobra Locks but I did manage to get some of the cam locks and the various mounts I've installed (i.e., ram mount for the Garmin Echo, another for the mini ipad and two for the gopros). By the way, the Ram mounts are the least economical, they know how to stick it you (each part sold separately) but again, its all relative a $60 RAM mount seems cheap next to a 6 channel amp, $300 for tint, etc.
One of the cheapest mod I ever did, easiest to install, and provides $$$ worth of protection. Cobra EZ Locks on the clean out plugs prevent blowouts. A few pics of why and what they are...
IMO, these should be on every clean out plug.
Noodle fixes...fill the table mount holes to prevent water from filling...install a SS 1/8" x 2" welding rod into the transom drain plug to make wrench free...store the transom drain plug in the swim deck noodle mod when not in use...fill the old style table legs with noodle to prevent them from sinking...cover table legs with large diameter noodle when storing them...use large diameter noodle across the top of the windshield to prevent chaffing of frame and cover...use large diameter noodle to cover hinge assembly on bimini during transit
I guess it was to me. The factory 360 light was always a PITA to attach and detach which usually ended in bloody knuckles. The new Navi light didn't require any wires as it is powered with battery's, the base is glued onto the tower and the actual light has built in magnets, I just bring out the light whenver I need to use it.
