Jgorm
- San Diego / Colorado river
I had some if this piled in another thread, but it's time to focus on major issues. Here is the history.
Test drive 2004 ar230, runs great, started up multiple times, no hesitation at wot, 10k+ rpm at wot. Decide against doing a compression test. Engines look super clean, no rust, no pits at all on the zinc, probably never been in salt.
Come back the next weekend and buy the boat (200 miles away). Take it to the river. Starts fine, runs great. Day two at the launch ramp I can't get the port engine started. I jiggle the lanyard, cycle the clean out switches, with no luck. I pull the air filter and it starts, put it back on and it won't start. Take it off and it runs great all day. I forgot to blow the water out, so I try to start it the next day and it struggles but I eventually get it running.
I discover the key switch has the yellow / red wire broken and think, easy fix. More testing shows that that wire doesn't do anything, and it starts multiple times over the next couple days.
Pull the plugs and they look fine, a little rich maybe on a couple, but pretty good. Run compression with the lanyard off, throttle button in, wot until max reading.
1 = 195, 195
2 = 100, 100, 100w, 100w
3 = 165, 165
4 = 205, 205
Seems to be valve related. What's the cost to take it in vs diy? Any chance an oil change and some hard driving might loosen thing up? (Yeah LONG shot, but I've "fixed" a transmission like that!) Could I eek out a season in this condition, or will I end up with total destruction?
I'm pretty mechanical, been dyno / email tuning efi Ford's since 2005 as a side business, installed superchargers, intake manifold replacements, brakes, axles, lift kits, etc, but I've never had the heads off anything yet.
This is not what I was hoping for with a new boat! Check compression before you buy anything! I'm kicking myself for not spending a couple hours doing a more thorough check.
1 = 195, 195
3 = 165, 165
4 = 205, 205
