ncnmra
Jetboaters Commander
- Ontario, Canada
- X
I have a 2008 212X (twin MR-1 engines).
I'm trying to hunt down why my port engine will only hit 9800 rpm, while the starboard will hit 10,000+
I noticed this issue all last year, and I had the plugs changed out before it was winterized (I know, I should have waited until the spring).
Other than plugs, what are some of the reasons for rpm loss? It seems that my port engine is slightly "weaker"; it takes a bit longer to spin up to full rpm than the starboard. I know that the impellers are different pitch, and wondering how that may effect things.
I have tried to swap the air filters between the two engines and if anything, it got worse than better. I'm tempted to try to run without air filters all together to try; but the manual strongly warns against this, as it may "cause damage".
What other things should I look for?
- Spark Plugs
- Air filter
- Fuel filters??
- Throttle cable (I have checked, it looks like its fully tight)
- Impellers?
- Compression?
Any other obvious things to check? Should I care? I rarely hit WOT either way, but I'm wondering if it may be a symptom of something else.
Do these plugs look "fouled" to you guys? It is #2 and #3 from the port engine.
- Spark Plugs
- Air filter
- Fuel filters??
- Impellers?
- Compression?
