betterwhenitswetter
- DFW, TX
Ladies and Gents, I need some help or other points of view.
This is not my boat, thankfully! But my PWC, 2007 FXHO MR1 so same engine.
Yesterday the family rode it my Yamaha 2007 FXHO PWC hard most the day, I got on it and noticed it was running extremely rough, and then the check engine light came on within about 10-20 seconds, so I stopped duh. The entire day the Yamaha water spout was shooting the normal amount b/c I could see it when they passed by where we where anchored , or appeared to be normal amount of water under all loads.
I pulled the seats only thing was there a "little" water in the hull, and the shore engine flush cap open/off. Come to find out my brother left it off, he earlier before we left for the lake said he wanted to run it on shore to test fire and forgot reinstall the flush cap.
Current know facts:
Yesterday:
Today:
Current know facts:
Yesterday:
- Check engine light, was on yesterday, No temp light came one LCD cluster, only check engine light.
- Also I noticed raw fuel at the time of it running rough.
- idle-towed it to shore using my AR230 boat, took forever nice and slow (I know the MR1 can get water if you tow them fast).
Today:
- Pulled fault codes, = code 24 CAM position sensor was stored occurred at 43.27 hours, total run time was 43.40 (Nothing else, all other data reads good engine off)
- Unable to turn engine over today, locked!
- Pulled coils and plugs Cylinder 3 spits out water and fuel (mostly water, I suspect unburned fuel is in the exhaust, mixed with water), water keeps pumping out only cylinder 3, every other cylinder is bone dry (these doesn't appear to be water from the exhaust being pulled back in by back pressure, cooling system, or as I suspect cylinder head failure, or exhaust valve failure.
- Engine turns over smooth no unusual sounds or physical mechanical sounds like a valve hitting the cylinder, again cylinder 3 shoots water plugs out.
- No water in the oil
