svana
- Riverview, FL
- SX
Well...I think I've been bitten by the repair bug this season. After all my other nonsense earlier this year, I've got a series of symptoms going on now that have put my 08 SX230 out of commission until they're fixed. Issue is I've got so many symptoms/issues it's hard to sift through them all. I've tried to list all the symptoms/relevant occurrences below and hope I can get a little bit of help towards some clarity on how to approach things.
Most simplified/important issues:
Nasty rattle in STBD engine
STBD engine overheating
Both engines absolutely drinking oil (no leaks/symptoms found anywhere in engine bay)
Timing/further detail:
Engine rattle
If I’m really thinking back I think there’s been some level of this rattle for quite some time now although not as pronounced. I usually turn both engines on one after the other (starting with stbd) so I’ve always thought that’s their normal sound. Not until I’ve had to run them separately have I noticed how pronounced the rattle is on the stbd engine compared to the port. I’ve included a video for reference, but the rattling really isn't as pronounced as it is in person. I’ve got no real basis, but is it maybe a timing chain issue?
Overheating
This was first experienced halfway through our Bimini trip a few weeks ago. I definitely took on a bunch of sargassum on the way there - cleared it twice but who knows how long I was running it for. The second time it was absolutely jammed in there, took some force to pull everything out, but there were no issues yet. As stated, about halfway through the trip, I was running the motors a little past no wake speed, about 3000rpm when I first got the overheat indicator. Looked back, and was only getting water out of 3/4 pissers. Shut the engine down, checked the clean outs, made sure the lines weren’t clogged, etc.. After a few minutes I started it back up, punched the throttle and it was fine. I figured maybe the rpm’s were too high with how slow the boat was traveling resulting in the cooling water not traveling fast enough. On the trip back we got to the meeting point outside of the sands where it was a little choppy so I was feathering the throttle. At that point we got hit again with the overheating light. I again checked everything and after a few minutes started the engine back up and rode home without issue (kept it at roughly 6-7kr rpm for about 1/3 of the trip then increased to normal speed ~8k)
When we got home and were rinsing the boat off I pulled a tiny piece of sargassum out of one of the pissers. Not big enough to clog the line, but this indicates to me that some sargassum made it all the way through the cooling system…
I was originally honing in on the fact that I was only overheating at the lower RPM’s as a data point until yesterday when we took it out (tempting fate, I know) and we overheated at speed shortly after leaving our 15min channel. On the way back I was overheating even at idle/no wake, so there went that idea.
Oil loss
I check our oil levels pretty religiously as part of my pre-trip inspection. The engines of course are cold at this time, so the level is usually low as is expected. Recently however the oil levels on both engines have been seemingly very low. They were a bit low during Bimini so I topped them off with about half a quart between the two engines. Yesterday I checked the oil levels during the overheat and they were both showing bone dry after running for some time. I filled about a quart between the two of them and they were barely recording on the dipstick. Also there was traces of smoke(?) coming from the oil tank when I unscrewed the dipstick. The oil came out clean, albeit dark. I skipped last year so it’s been 2+ years since I swapped the oil and plugs, although we definitely don’t take the boat out as much as some here unfortunately… Also of note, there hasn’t been any evidence of an oil leak in the boat. A little sooty around the jets but seemingly not out of the ordinary.
Well…that’s the gist lol. I’d love to hear any ideas that folks may have. At this point I’m thinking about trying to get on the list for a local shop but everybody here is weeks out at least and I’m sure it’s going to be $$$…I’d love to avoid it if possible but it’s a little overwhelming at the moment.
Engine rattle
Overheating
Oil loss
