Berberman
- Massachusetts
- Other
I’m going to document my chartplotter install here, ask questions and hopefully receive feedback along the way on what I’m doing right or wrong or can do better, but also so that others can benefit from it down the line. Let me start by saying I’m relatively new to boating, so please pardon my ignorance.
Boat is a 2022 AR210
Chartplotter: Garmin Echomap UHD2 94sv with GT56 transducer.
1) Transducer placement and mount:
I’m getting the Garmin tomorrow and will have a better idea of the size and placement of the transducer, but right now i think I’m installing it on the ride plate. There are 3 clear choices for the mount: a) one that comes with the transducer that’s plastic, which logically would break off easier if it hits something, thereby not putting stress on the part of the boat on which it is installed (transom or ride plate), I’m thinking of installing that on the ride plate, or b) a metallic one that provides rigidity and most probably less vibration (Amazon.com)
I’m leaning towards the plastic mount, as I’d rather loose the transducer rather than making repairs to the fiberglass. That said, I may also try @Julian ’s, @HangOutdoors or @JASmith ’s custom built aluminum mounts, which have the bottom of the transducer sit a hair under the keel line, hence providing optimal imaging.
-Question: For those who installed the transducer as shown in the pic below, hence above the keel, are you getting decent Side vu imaging?
2) Cable route:
I’m still working on part (1) right now but I have to say part 2 terrifies me: I need to drills holes into the fiberglass to secure probably 2 or 3 cable clips onto the transom (these should be ss screws), and I also need to open up the swim platfom and drill a hole for the cable to enter the area under the hatch. I‘ll need some type of cable clam for that. Then I’ll need to make my way to the engine bay, starboard side and follow the rest of the cables up to the helm. Right now this whole process is a fog and I’ll be crossing that bridge when I get to it, documenting it along the way.
-Questions: Anyone know whether the Garmin unit comes with the cable clips and the through hull fitting/cable clam?Otherwise I’ll go with this: Through Hull Fitting
What diameter hole is needed for the cable and cable clam though hull fitting?
What sealant would you use for that? 3M 5200 or 4200? Is there a Loctite equivalent? (Home Depot carries Loctite, so it’s easier to pickup)
3) Garmin unit installation on dash:
There are a few options to go about this, and I’ll be thinking about it and will document when I have a better idea.
Wish me luck.
2) Cable route:
Wish me luck.
