Michael Strutton
- Villa Rica, GA
- 242 Limited S E-Series
Only 7 hours on my new boat and I sucked my first rope. This happened because my rope person was distracted on their phone and my tube spotter was upfront. I had been cautious about the rope but I also had that momentary lapse of neutral being safe (like my previous boat).
What made matters worse was I had used an old tow rope with some knots to make a 10-12' extension on my 60' tube robe - keeps the kids out of the wash. The knotted short rope with the connecting knot and the beginning of new rope got sucked.
I don't know if I needed to, but I first cut the rope from below the boat through the grate. There was a knot jammed there and it look like it would help loosen things from below. It took at least 10 dives to get that first cut. My knife would barely reach through the grate so I was just scratching at the rope with the very tip of the knife. I then proceeded to saw/slice the tightly wound bundle along the shaft from the top clean out portal. That quickly removed the rest of the rope in 4-5 pieces.
Before cutting I realized I only had one knife on the boat. Fortunately it was a sharb lock blade. My first thought was what would happen if I dropped my only knife. So un-braided some tow rope and made a loop for my knife. Then I attached my floating bungee dock rope to the knife loop.l and use this as a leash.
So I'm really glad I got this experience under my belt. I will say I was little rattled at first but now that I've done this, I have more confidence.
I plan on buying a better knife (more than one) and reinforce the job of rope duty.
Is it common to go under the boat or was that unnecessary? Fortunately it was warm water and nice weather.
Any recommendations on the best type of knives or other tools to keep handy for jet port clean outs?
