Tutankhamun
- FSH Sport
Please help! My fsh 190 sport 2022 won't go past 22 mph. Am I doing something wrong?
Yes from the start....I only use it for 8 hrs. To be honest I thought that is standard and when I finally decide to take to the dealership my 1 year warranty past and they wanna charge me 200$ just to take a look at itIn addition to @Can0n11 question I would add, has it always only gone 22 mph?
I really didn't payed attention to that because I thought it was normal at 22What Rpm's are you running at that speed?
You have to run the blower for 5 minutes then switch on the turbo. Standard stuff for the 190, if that doesn't work you prob have a bad impeller.
190 sportThat is super important to know. It could be as simple as the throttle cable having too much play in it.
Just to confirm, your boat is a 190 FSH Sport and not a 195 FSH sport?
The boat is at my houseIs the boat ready for you look at right now? Or away in marina?
I have 2 extra batteries for the trolling motor and most of the time there's only 2 people on boardI dont see where you responded with the RPMs? Also what is your standard load on boat. How many people and gear? Sounds like either overloaded or high altitude as the 190's are under powered anyway.
