Jameson Clark
- Laurens, SC
- X
When I got my boat this spring, it was my first jet boat. But, I have been boating as long as memory serves and was raised going to the lake on the weekends. I was raised boating on O/B ski and bass boats and switched to I/O when I bought my first boat. So, I obviously was used to that type of handling from a boat. When I got my Yamaha, it was... different. I joined here and started reading. After about 40 hours of use, I felt I had a pretty good handle on the boat and knew the areas I wanted to improve for my style of boating. Listed in order of MY priority were these items:
1. Sharper turning when on plane. This boat seemed to never be able to "dig in" when needing to whip around for something like a down skier or someone coming off a tube. With the wheel turned all the way, I just felt like the boat slid across the water and I didn't have the sharp turning power/ability I was used to.
2. Better tracking when on plane. Once again, being used to outboards and sterndrives, this boat seemed very loose going across rougher water. I had never felt a boat move around in the rear like this one. If I hit a wake at 45 degrees or so, the rear of the boat would move all around and point the boat in a different direction.
3. Better reverse power and steering. I don't think this needs much of an explanation. Yamahas just don't do a very good job with the reverse on these boats and it is very noticeable. While it wasn't the top of my priority list since I have learned to use the twin engines to help this, better reverse power and authority is never a bad thing.
4. Better slow speed tracking. This one was at the bottom of my list because I really didn't think this boat was that bad really. Maybe the newer AK style boats aren't as bad with the rudder? But, even my I/O boats wandered at idle speeds and you couldn't expect the boat to go straight with no hands on the wheel making corrections. So, for me, this boat felt pretty close to what I was used to. But again, if it can be improved... great.
Seeing what my priorities were and doing my research on the two main steering systems and what they correct, I chose the Cobra system. So, after a weekend of boating on busy Lake Keowee, I thought I would share my opinion on what @Cobra Jet Steering LLC system did for my boat in these 4 areas.
1. This was my biggest priority as the poor turning performance of this boat had already almost gotten me in a bad spot once and thankfully this was one of the most improved areas! I had read reviews saying how well these boats turn with the Cobra systems but I was skeptical... It absolutely 100% solved my complaint of this boat! It turns as sharp, or sharper, than my last I/O and also now bleeds off less speed in normal watersports steering and maneuvers. The boat feels like it really digs into a turn now and it is exactly what I was looking for. (100% improvement for me)
2. Much much better tracking through rough chop. I could still feel the boat move around slightly in the rear on some of the worst chop where wakes from multiple boats came together. But, the boat feels so much more planted in the water and drives straight with hands off the wheel now. With the added MEGA fangs, steering effort did not increase from the added drag of the fins when turning. I can't say that it got easier, but I had no issues with the boat being hard to turn to begin with. (90% improvement for me)
3. I am not convinced a jet boat will ever perform like an I/O in reverse and that is just due to design I believe. However, the MEGA fangs did improve reverse power and steering substantially. I feel like I have more authority in reverse for sure. For crazy tight reverse maneuvering, I use engines in opposite direction to accomplish this and it did better with the fangs for sure. (70% improvement for me)
4. Like I mentioned before, I did not have a major issue with this area before like many seem to. But, once again, it did improve it quite a bit! Obviously this jet boat took more steady corrections when idling than an I/O but it just didn't really bother me. Well, now it tracks much better at slow speeds! It needs less steady corrections and I am able to get up and go grab a cold refreshment and come sit back down and the boat is still headed in the same direction. So, for it to not be a big deal for me, I was still pleasantly surprised with how much better it got. I don't really think it wanders anymore than my last I/O at idle speeds now for sure. (90% improvement for me)
So, overall, I 100% recommend this system for anyone trying to correct any of these 4 issues! This system offers other benefits I did not include here but for me, these were my concerns and it did a terrific job at correcting them all with one system at a very reasonable price. If I can answer any questions for anyone, I'd be happy to give my HONEST opinion of anything about it.
PS - It should be noted that I had a question about the install and emailed Jeff ( @Cobra Jet Steering LLC ) at 9:30pm and he responded within 10 minutes...pretty good customer service right there!
