sethman919
- Apex, NC
So, The original tower racks on my AR230 were pretty rough when i got it. They were a solid design that held the boards well but the finish on them was shot. I often take a knee board and or the Zup board with me. So, I started looking for a combo rack and a matching just wake board rack. I ended up with cheap racks form Origin. One that came with the rubber inserts. These were a nightmare. they came with the typical rubber inserts to adapt it to your tower tube diameter. they would rotate down til the boards were angled down under almost any conditions. I tightened them and then even added a set screw to them. they would still rotate. with so much space between the clamp and the board with the large adapter they broke the ends off the set screw. So avoid this type of rack.
So, I've moved on. I ended up buying the Krypt quick release racks that are ordered with a clamp specifically for your tower dimension.
What I'm wondering is if anyone has mounted theirs lower on the tower. Seems the added weight on the high horizontal bar really makes the tower move a lot when hitting wakes or chop. down lower seems like it would be much more stable location. I cant seem to find much information on any drawbacks to mounting them lower. I'm even contemplating mounting them to the bar that parallels the windshield. anyone have thoughts?
