Navigation lights not working on sx210.
Relaxsingh
Miami
Hi, today I was checking my navigation and anchor lights, they are not working. The light on the switch comes on, but the lights do not work.
Can anyone tell me what to check?.
Where can you buy the bulbs and the anchor light socket.
Thank you
I would verify that you have power to the sockets. If you do then the next step would be to make sure the bulb is good.
Next to the switch (on mine--not sure your year) is a little button that I never notice. It is a breaker under a little rubber cap. Push that and see if they magically come on...
Third thing to look at is to see if the bulb is being held tight in the fixture. I had to bend the metal in mine for it to maintain firm contact. (Also if it is a festoon bulb, and an LED bulb was put in, flip it around, it may be backwards.)
