Need a good repair shop around Houston
08AR210
'08 AR210 water in oil, can't remove it w multiple oil/filter changes, possible overheat. My mechanic on my lake is out of commission. Need a good repair shop who can pull the motor and do the repair. Scared of dealer labor rates. Anybody know a good shop around Houston area that you have had engine work done? Thanks
I have heard of WFO Permormance, and even called them once (713) 725-8596 but never have actually needed them, so my reference is pretty terrible.
In the past when similar issues have been reported, in some cases it has been a gap in the exhaust manifold. It might be worth it to inspect it before giving it to the shop. Best of Luck, hopefully the other members in the area have a better reference.
I took my boat to the dealer (Texas Marine, Conroe) for the first service. After dropping $450 on oil and plug change, I found the (ahem) other site, which then led me to this site. I learned there was basically very little I couldn't do myself on these boats (given a history of shadetree auto mechanic work). As a result, I have less to offer you than @Beachbummer. Never had an issue of that magnitude with my engines (yet--knocking madly on wood), so haven't had to find one.
But I found a good shop for fiberglass work, courtesy of a tree stump. I know, not helpful.
Do let us know what you find, tho. This board works by shared knowledge... Hey, @MrMoose , did you ever find anyone when you were down here?
Looks like the Member Map is not working correctly. @Bruce , were you aware? But I know there are a few more Houston area folks here...
We are not entirely happy with the current member map but it is the best available for this version of the forum software. Unfortunately later versions of the map that we previously used were unusable at our scale.
Thanks guys, will check with WFO. Normally I do all my own engine work, but my work is taking all my time and I want to be on the lake soon. Dealers will take all your $
@tdonoughue , nope, the only work I ever had done on my boat was warranty work, mostly done by Texas Marine in Conroe.
Unfortunately no. I had to use Texas marine for my engine swap because it was good will by corporate. I haven’t had any other shop work on my boat. I did have an automechanic I trust double check some work, but I don’t think he would be interested in significant marine work.
