Danforth anchors are built for sand and mud. Best hold you can buy-
Larger boats have had issues with bending flukes on wind shifts, because the anchor holds too well.
Next Generation anchors like Rochna and Manson have largely taken over the market due to their near ubiquitous terrain capabilities (mud, coral, sand, weeds,...) and ability to quickly reset, on a wind shift.
Though we did this upgrade on our previous boat (45lbs Danforth to 55lbs Rochna; 10 ton catamaran), don't plan to do this, this time.
-Vast majority of our anchoring in day/lunch hooks (we are with boat, on clear weather days)
-Vast majority is in sand or mud, which danforth's are good at
-Use 3-4:1 scope and conscious to use reverse to set the anchor in (3K+ reverse). (Note that scope ratio is measured from where the rode is secured to boat, not the water depth).
-Storage is premium on our 242X, with so much going to ballast.
-Bought the Danforth S600 anchor kit, which is what Yamaha uses for it's 'Deluxe' anchor. 9lb anchor, 150' line, 4' of 1/4 inch chain. I would prefer 200' line and 6-8' of chain, but the kit is easy.
Anchoring (like docking) is mostly about technique/practice in setting and somewhat about the anchor and the bottom composition.
Too many boaters are too focused on their post anchoring activities (and sometimes the crowd), to anchor well.
Our routine (mostly stern to beach anchoring):
-Nose in to where we want to anchor and get a feel for the depth gradient (how quickly it gets shallow...gives me idea how deep I need to set anchor out at, to be waist deep at stern, with the right scope).
-Back in and drop anchor off bow in 10' of water, when 40+-ish feet from beach (distances dependent on the beach gradient)
-When short of where I want to end up (say 10-15' from beach), secure rode (anchor line) to cleat, and 1st see if it stops us, if so, then reverse on it to 3K, and make sure still holds.
-If holding, then release rode and keep backing towards beach to the depth I want the stern to be at.
-Secure line to stern and walk off to secure line ashore. (mostly tie to trees by me, but considering the Shore Spike; easy storage)
Any feedback from folks on the shore spike?
I don't have anything against the box anchor but simply don't want to give up the space and with some practice, the designed solution is more than capable for our primary use-case.
