Need anti-pooling pole replacement set for cover
raptor319
242 Limited E-Series
Hello there I need a new anti-pooling pole set...the straps on mine have become worn and it doesn’t look like they’re easily replaced. I can’t really find a comparable set for my 2016 Yamaha 242 does anyone know where I can get this?
I've got a spare set for an AR190. Doubt that helps with your 242, but if it does it's yours.
You can usually get that nylon webbing at local fabric stores. Assuming you know someone with a sewing machine and the poles and plastic is still in good shape you might be able to rebuild what you have.
STRONGLY recommend the Hangtyte system... Especially on the 242 LSE's
Pretty sure @swatski did this as well and has a write up somewhere on this system.
Search Hangtyte on here, you can't go wrong!
Yessir!
The hardest part was cutting holes in a perfectly good premium cover, lol. The system is awesome, I installed two and they have been a lifesaver with the lift.
Thanks for the advice if I had a wake tower I guess that would work but I do not have a tower on my boat
I appreciate that...but the poles are fine I have the same issue as you...nylon turned to dust in Hot Florida weather
We just got a new cover and i'm pretty sure the old anti-pooling pole set is good. I'll check when I get home today, if they are in good shape, just cover the shipping and they're yours.
And don't forget you have some canvas to pick up for those projects, currently stuck on a shelf in a STL, MO, garage, lol.
Didn't forget, just been crazy times here. I'll be through on the 26th. Replied to the conversation with @BigAbe75 We'll get it out of there.
