andyak1
- houston texas
I have ar210 2007 bought with blown port engine.
Just finally got YDS up and running
good news - starboard shows boat has only 126 hours on it
the repowered port engine has 76 hours and is using ecm from ski as the boat ecm is
repower Port engine is erratic in that it bogs down and only runs up to 9000 plus rpm after first started, then bogs down and won't go over 2500.
Looking at YDS - the good starboard engine has very stable timing at 5 btdc at idle and increase when throttling up.
port engine has timing jumping around over 10 btdc at idle and seems to be erratic.
This port engine was in a ski that was totalled because it fell off lift into lake - so ski was in water for awhile. I have clean oil now that has stayed clean through all my testing. I replaced the oil cooler with a fresh cleaned one and took off pan and cleaned it all out with new gasket.
any ideas why timing would be erratic? I guess this would either be the problem or the symptom.
HELP PLEASE
Andy
HELP PLEASE
Andy
