I just bought a new battery for my 05 challenger 180 and when I try to start it nothing happens.. lights horn etc. Work fine. What could be wrong? There’s no power after relay.. any help would really be appreciated! Thank you
I’m in no way familiar with your make and model. But it sounds like you might’ve left a ground or positive wire connection off when you replaced the battery. That would be my first inclination. Hope you figure it out soon.
Check to see if you have accidentally unplugged your starter relay or if a wire has come loose. I have forgotten to plug the starter relay back in many a times when working on jet skis. all electronics work but there is no cranking form the engine upon starting.
