need help boat will not start
jetboat keith
SeaDoo
Challenger
hi every one i have a 1999 seadoo challenger 1800 with twin motors one side will start but the other side will not start it clicks when you press the start button i did replace the starter relay but still will not start any ideas on what to do next any help would be appreciated.
Check ground connection at starter motor.
And welcome!
I'm with WREKS start with cleaning cables on back of starter. You did not say what of battery switch/ single battery/duel batts. While you are cleaning cables on back of starter just for fun clean all contacts on Battery switch and visually check all cable runs down to starter looking for wear damage ect........ After that I would I lean towards solenoid/starter testing.
A 1999 engine is getting a little long in the tooth I would suspect a worn out/corroded starter.
