Ryan1978
About a year ago, I bought a 2013 AR210. Within the first outing or second boat over heated. Took it to a mechanic and he supposedly flushed both engines. Took ot out about a month ago for the first time and immediately the port side engine overheated. I have read the threads and I have done everything everyone suggests. Changed oil, spark plugs and thermostats. Both engines over heat about 15 to 20 minutes in the water and within seconds of each other. I flushed the engines with salt away aglfter each use. I do have water coming out of the pissers every time. I am in VA and use it in brackish water.
I just bought a thermometer gun to see if I can pinpoint where it is getting hot. Does anyone have any other suggestions for me to look at? Does anyone know the temperature that engine and the exhaust should be running ? Any help is greatly appreciated.
