Need help getting wheel off riding lawnmower
Scottintexas
Staff member
Corinth, TX (DFW)
Need help getting rear wheels off axle of jd155c riding lawnmower
Going to replace the transaxle unit,
Took dust cover off
Removed c clip and washer
Everything on internet says they should slide right off
This tractor was under water for three days and don't know if wheels have ever been off, at least not in the last 10 years
While still attached to the mower i beat on the backside with 2x4 and 5lb sledge, ALOT, REALLY HARD, didn't move so i decided to pull trans with wheels on
Tried to put a jack in between with 2x4 for some constant pressure and knock on the axle but it doesn't get a straight up pressure
Picture of new unit also and doesn't appear to be any attachment points at the inward
Going to spray it with some break free and let it sit tonight
Any other ideas to try ??
@zipper
@Babin Farms
@Bruce
Took dust cover off
@zipper
@Babin Farms
@Bruce
View attachment 199721View attachment 199722View attachment 199723
Heat is your best bet in that situation, it looks very rusted up. If letting it sit overnight with pennetrant doesn't work get the wheel part hot with a torch.
Keep spraying with penetrant for a few days but first clean the end of the shaft till it’s nice & smooth. Emery cloth is what I would use.
Do you have access to a press? If so you could try to press it out with hydraulic pressure. If not try to make a stand to have the rim sit on and either use an air chisel on the shaft or just a BFH and punch. Just be careful to not mushroom the end of the shaft or you’ll have bigger problems.
I like the clean then oil and torch ideas better than my own but if those do not work I would consider grinding off the part of the shaft that is beyond the wheel to see if that helps with removal. If not perhaps cut the axle and see if you can drive it out from the inside.
Do you have an air hammer? If so, maybe try a smoothing bit to help your penetrant work mo betta, or break free anything that might help you in your quest. Like @Babin Farms said, be careful of mushrooming the head, maybe use a 2x4 between the smoothing bit and the axle, that way the wood will take the forces that will mushroom the end, while still letting the vibrations work their magic. Might take longer to break free with the 2x4, but it helped me remove a bed bolt from my F150.
If you've got the materials, maybe mix up some Ed's Red and try that in addition to the Break Free? I've had good success with Kroil too, but if it's not on hand, I dunno that it'll be worth the expense or time waiting for it to ship to you.
Not much else to add. Heat is your friend. Don’t beat on the end of the axle. If you have to, do it with a brass punch. I’d say use a puller but I don’t know of one that will work with a tire.
Success !
Neighbor had an air chisel, it didn't really do anything, he had a hitch pin that fit nicely and after a hundred swings of the sledge one came out, just a slow back and forth hanging it off the tailgate
Success !
Was it just that rusted in there? It didn't look like there'd be much holding it other than rust, but if it was all the way around, that'd be more than enough. Anti-seize to help with removal if it's needed in the future? Not a silver bullet, but better than nothing.
Fixed !!
There was a fine layer of rust all around the axle on light roughness inside the wheel,
Cleaned the wheel with my wire brush and applied liberal amount of antiseize on the axle
Drove it up/down the street in the dark and it drove much faster, hopefully mow this weekend
It would have been a two hour job without problems but turned into about 6
The old one, i may pull the hyro pump and see about lapping it
