GTBRMC
- Waukesha, WI
- Boatless
- SX
Will get pix up later, not 100% sure on model and year, but I think it is correct (3 passenger, 1.8L normally aspirated, was $15K ish new a few years ago.) I got too shallow on my brother's (UGH!) ski. Sucked rocks into intake. Obvious gravel noise in impeller. Stalled engine.
Got ski onto its lift, there are obvious dings in impeller edges, assume there is a pebble stuck between wear ring and impeller and that stalled the engine. I am guessing I am going to have to buy him a new impeller and wear ring, but I'd like to get this fixed now so we can use it for the next few days (depending on how bad the cavitation is). I have to run into Lowe's to get a socket set to pull pebbles from intake side of impeller (will have to pull the intake grate plate (whatever it is called). I also can see a couple on outlet side - going to have to get some long reach right angle needle nose pliers for that.
His ski has the trim adjustment and reverse buckets in the way, pulling impeller looks much more difficult than on my sx-230. Can anyone give me advice / guidance on a) how to get the ski going again for now and b) how big a bill I need to brace for with new impeller and ring and paying someone to do it (quite sure he won't try, I am from out of state and likely will not be here to do it)? Could really use some [USERGROUP=9]@HELP[/USERGROUP] here.
&$%& damn &@*#& it! My fault, I have to make it right.
