Need help with identifying part number
symbianx
Wake Forest, NC
Still getting used to docking these boats and hit the dock a little hard. Where can I order this missing piece? Or at least what is it called?
Thanks!
If there the part you took off looks like the other 2 that should be the water bypass outlets. You can do a great upgrade here Water Bypass - 1/2 45 degree
If the part you took off is flat and round then it should be the bilge outlet, again a quick easy upgrade
Bilge Outlet - 3/4 inch
its " cooling water pilot outlet" . but wondering where is the bilge outlet of 19 model ?
That is not the bilge outlet. The bilge is much larger and round. The bilge on previous year 195's used to be aft of the other pissers. The 2019 195's they moved the pisser outlets much further back near the rear cleat, however the bilge outlet remained in the same location as previous years. Probably related to the revised and wider hull.
2018 195....
2019 195....
That broken "pisser" as they are affectionately called on here is one of the two for the intercooler. The one on the left (rear most) is for the engine.
People who break them typically just go with the nicer metal fittings like mentioned above. You can see more by searching "pisser" in this section. Also see this thread https://jetboaters.net/threads/peehole-name.17999/#post-308334
wow, how a change they made 3 pissers near real cleat, that must help to boost the speed bit faster than my old 18, lol ..............!
The 1/2 inch is too big. Wont fit through the port in the boat. Guess ill try the smaller ones. No one knows the stock part?
oh and stock part for future searchers.
F4V-U753B-00-00
