Melo
- SR
Hey all I'm new to this forum thanks for all the great info posted so far.
I apologize for the long read ahead of time.
My question is in regards to the 2 M1 engines on my 2006 Yamaha jet boat. The initial problem started in one engine where I noticed a decrease in RPM while out on the lake and when I came to a stop and turned both engines off to float and enjoy the water. Then that engine would not start or even attempt to turn over....
We put the boat back on the trailer and it sat for about 2 weeks before I could look into it and much to my surprise the engine that failed started right up no problem.
I then decided it may be a good time to change oil filters and Spark plugs. When I did so I noticed a lot of oil near the 4 manifolds next to air filter....
Cleaned it all up changed oil, filter, and Spark plugs fired them up and saw no issues.
Took the boat out to the lake once again and (see pictures below) but now both engines are spitting out into the air box a shimmering liquid and smells like gas and oil mixture of some type.
What the heck am I dealing with here?
