dscable
- Crawfordsville, IN
OK guys. I had to replace the reverse gate cable about a month ago. Boat is running fine, but feel like I lost a little bit of speed and "hole shot" power ever since. Took some time to look at the reverse gate again today, and notice that at WOT it doesn't appear to clear the whole nozzle (see pics). That doesn't seem right to me, shouldn't the gate be completely up? If so, I have maxed out the adjustment, and the lock nut is all the way up the threads so no more adjustment space.
Now - I noticed on the parts diag (see pic) that part 42, called a collar, is missing on my setup. I assume that those collars allow that bracket to "swing" in it's connection points. Could this be my problem? Mine is tightened down tight and doesn't spin at all. To test, I loosened the bolts a bit to allow for the freedom of movement, but it didn't APPEAR to make that much of a difference.
Any ideas??
Any ideas??
