Need some opinions
clint6760
Ozark, AR
Looking at these two pictures of these boat wraps/graphics kits, would you assume the black part in the middle of the blue designs would also be included in the wrap or not? I am talking about the part that has the small white writing. I know these are two totally different boats and one has a black hull and one has a white. Thanks
I believe the black in both pictures is the hull color and the blue and white parts are the wraps.
You can see a couple different hull colors here and if you scroll down, you can see a wrap installed on a black boat.
I would say the black is the center hull color....unless you specified you wanted that part of the boat covered in the black color.
Thanks. I was assuming it was part of the graphics and was wrong. The blue stripe on the hull of my boat is nowhere near that big compared to the black in the pictures so the graphics don't look the best. image.jpgimage.jpg
Ahhh... Oops. That rather sux.
So, there was some confusion. It happens. It does suck but it could be worse. Have you spoke to the company that produced the wrap ? Maybe they will work with you somehow. Maybe you can measure the white parts and them make the "black" parts to fill them in. The good news the wraps you have look pretty cool either way and will definitely help your boat be different from the rest.
just ad a new white stripe on each side to cover up your existing blue stripe.
Yeah I spoke to ipd. I was under the assumption it was all one piece. I'm fine with the blue of it was larger and more matched the graphics. I think it looks terrible with the small blue stripe. Also the Yamaha logo is cut in two pieces as you can tell and I guess because of the line in the boat. The crease that is there makes the logo look out of line or something.
I can't really add a white stripe because it wouldn't be a close match since my boat is 12 years old.
Maybe they can make you a black part to go inside?
Yeah That would be nice but it would have to be blue since the blue stripe goes all the way around the boat.
I came super close to buying their graphics with the sale/promo or whatever last year. Was ready to hit the buy now until I realized it was just partial graphics. Nothing matches or complements yacht blue.
Actually, I bet you could get away with the blue stripe coming out of the front/back with just the black in the middle part....
Thanks for the help and the opinions. I don't know what I'm going to do. To me the stripe in between, in front of, and behind the graphics needs to all be the same color which the only way that would work would be blue.
I'm probably just gonna say screw it and leave everything off because I'm not fond of it. I also haven't thought of what to do above the rub line because the graphics go above it.
Dang, that would have looked sweet on a solid hull color. I hope you can figure something out.
