Need to remove tower speakers?
Crlos16
Houston TX
Need some help, I’m trying to remove the factory tweeter speakers from the tower of my 2009 232 Limited S jet boat. How can I do this with out damaging the tweeters? Has anyone done this before?
Did you ever figure this out? I want to remove and use the wires for tower speakers
It’s really easy to remove the tweeters from the tower. They are held in place with a rubber grommet. Just use a plastic and dull pry bar (plastic butter knife will work) to get under the lip and pull it up gently as level as you can. Liquid soap or silicone spray will help if the grommet is tight. Good luck.
