Banditgrrr
- Las Vegas, NV
- AR192
Below is a diagram of what I've installed over the past month. The users here have been extremely helpful in helping me get everything in working order on my boat so I'm reaching out once again since Bazooka tech support is closed for the weekend. I just purchased this Bazooka amplified bass tube. I read through the instructions and it says you can either use high level speaker inputs or you can use low level RCA inputs. I have tried both but get no sound from the sub. I get the power light and I have verified the remote power is wired correctly. Here is what I have tried so far:
1. Connected the "subwoofer RCA's" from the head unit to the tube. I turn the "subwoofer out" on in the head unit and set the gain to 5 (it goes from 0 to 12). I slowly increase the gain on the built in amp on the sub and still do not hear anything.
2. I disconnected the subwoofer RCA's from the head unit and turn the "subwoofer out" to off on the head unit. I then connected the front left and right speaker outputs to the high level inputs on the sub. Again tried to increase the gain and nothing happens.
3. I disconnected the Front RCA connections from the head unit to the Rockford amp as I know they're working and I connected those to the amp. Still no bass coming from the sub.
There is an RJ11 jack on the sub but it did not come with the potentiometer for volume. I would not think this is a requirement as it said it's an optional item and I wouldn't think that would prevent any bass from being heard. I'm at a loss for what to try next. The diagram below shows my connections. The arrows in red are not connected at the same time but I have tried them both separately and neither gives me bass output. Is there something I might be missing? Hoping to get some help as Bazooka tech support does not open until Monday.
