Nemea 2000
Jim190
Does anyone know where the Neamea 2000 interface port is on the engine of the 190FSH?
glad to have you on board,
if you do a search this was recently discussed a month ago, along with many posts years ago,
What are you going to try to do with the information? The engines won't synch up with chartplotters even though they are compatible.
Hi Scott,
Thanks for the feedback. And yes, I am attempting to sync the engine data with my Simrad GO7.
I did a quick search but could not fine the post you reference.
Thanks!
if you look at post #22
https://jetboaters.net/threads/simrad-go7-and-yamaha.7472/page-2
also, our search function at the top right of the page isn't the best, if you will put in nema or nema2k, nema2000 it will pull you up some other hits,
we had a computer engineer able to tap into it but it took him a lot of hours and wasn't anything easy to share with us,
it's unfortunate and not easy for someone like me to understand why it's not functional.
Where are you at and what do you normally fish for ?
Thanks for the info, I’m going to go to west marine and return the cable I purchased! Gotta say this is a little disappointing. But hopeful Yamaha will correct the issue.
I live in North Carolina and fish Wrightsville Beach area and Lake Norman.
