2kwik4u - the three water outlets are all engine cooling on the supercharged engines. My 2019 AR195 has three.
And just so you know - my bilge is as dry as a wheat field in August... haven't had to use my bilge once all year and my boat is moored in the water...
The pics and specs are contradictory - specs say 4 speakers, pics show 4 + towers.
- Tower speakers are an easy add IMO, so not a ton of value there.
- The walk-thru door addition is a nice touch, depending on how it's setup/integrated.
- Is that an 8in sub on the starboard rear storage wall?
- Looks like the center rear cushions unsnap and are possibly removable. That would be a nice touch that is needed. Wonder if there is SeaDeck under that seat for walking on?
- Does the 195S with the larger connext screen get Audio Controls? The 190's and 195's still show the remote for the stereo at the helm. I'm guessing the 195S changes that
At first I was bummed that right after I bought a brand new boat, the model was redesigned but now I like the 2018 better overall.Most of it is the 2019 update I still don't like 100% though.
I can't picture where you're talking about. You mean under the glovebox?I do like the black molded storage area on the port side beside the front passenger seat. There is a ton of space there on my 190 that isn't used, and I've been trying to figure out how I can "mold" something to fit in there to hold drinks and stuff.
I just assumed it was because the wakeboard bags tend to be put on the port side but just a guess.Wonder why they moved the ladder to Starboard from Port?
Thanks for the answers.The pics and specs are contradictory - specs say 4 speakers, pics show 4 + towers.
Pics don't show walk-thru.
No that's a 6.5" speaker, part of the "4".
No Seadeck under the removable cushion, just diamond plate for anti-slip.
Yes the Connext has audio control slaved to the Fusion stereo in the stern.
I want to retrofit that walk through door to mine
I see it now but don't you have the J-seating (like I do)? There is not really any space there to play with is there?Beside the passenger seat. If a passenger is sitting in the seat facing forward they can touch it with thier left hand.
The other is right across from it at the same location, closest they could get to match I suppose. I notice they changed the layout of the comming pads so they couldn't put them behind the driver/passenger buckets. A slight compromise I suppose. If the speaker system has a wet sounds amp, it won't matter much as they'll crank out the tunes without effort.Odd place to put one of the (4) speakers.
