Matts18
- East Tennessee
Longtime forum reader, finally traded in a sterndrive runabout for a 2018 AR 195. I have already replaced the bow roller and added the boat buckles thanks to (or should I say no thanks to!) this site. Due to a weird driveway, the articulating keel gets to within about 1/2 inch from scraping when I am backing the boat into the garage. To give myself some breathing room, I have ordered some 1.5" spacers to go between the axle and springs as well as some 15" aluminum trailer wheels with slightly larger radial trailer tires to give about 2" total of extra clearance. The plastic fenders have plenty of room for the larger wheel and tire (especially with the 1.5" life) and I have no issue on garage door height and the ramps are all steep around here so I don't see any adverse effect the additional height will have.
Anyhow, does anyone have any recommendation on how best to jack up the shoreland'r trailer? I have tall 6 ton jack stands and a good 3 ton floor jack. I am thinking it might be easiest to hook up the trailer to the truck, drive up on top of some ramps (keeping the truck attached), then position the stands under the frame behind the wheels, jack up the axle under the spring pad and take off the wheel, remove the ramp, and lower the jack to relieve pressure on the spring. At this point I can undo the u bolts and drop the axle down enough to insert the block, then button it all back up with the longer u bolts.
Any other thoughts or suggestions? Sorry if that has been covered elsewhere, I did search!
