PirataCoqui
- Raleigh NC
- 222SE
2023 222SE owner and posting partly to vent and partly to see if I can find an answer:
Issue number 1 and most concerning to me is that the last 2 times out we have had starboard engineoverhead overheats after about 20 minutes varies throttles (not always full throttle, just to get it on plane) and after slowing down and moving slow through the water at my destination( 15+ feet of water), I have gotten starboard engine overhead.
Both times the pissers where both working fine, checked clean-up ports, and looked at the strainers from the back of the board and everything was clean. In both scenarios, we did some ZUP boarding at slowish speeds and never saw the overhead ahead for the remainder of the day. Both times I have found no smokin gun, which I am not sure if that is good or bad.
Other information that might be helpful:
-The connect screen tends to reboot randomly while in float mode when listening to bluetooth music with no apparent pattern. I have not seen the issue while listening to the radio.
-I had an overhead once while flushing over the winter while on the hose that I attributed to bad water pressure.
A little baffled at the overhead issue and after searching the site, I intent to remove the strainer to inspect, blow air from the pisser backwards to try clean anything... should I be checking something else?
Kinda mysterious that when I don't pressure the engine as much I don't see the overhead, and I can't tell if this has always been an issue as I got the boat over the winter and mostly did low speed runs since I had my babies on board.
Thanks in advance!
Other random things(My rear transom ladder fell off, my guess someone forgot to lock it into place), just ordered a new one. As far as the screen rebooting, could care less and will take it in when the time is right, but I mention it in the event that it might be related.
BTW, I am jet boat in many ways due to all the reading I have done on this forum, great community!
Thanks in advance!
